Which degree toe-in and bearings for the Hostile One-Piece Rear Hub Carriers?
neeper
Vancouver, Canada
I'm looking at getting the Hostile One-Piece Rear Hub Carriers for my Baja 5b rears and wanted to get people's thoughts on it. I was thinking of getting the 3-degree toe-in with the big-bore bearings. Is the light-weight model with the standard bearing size a better route to go with?
neeper
Vancouver, Canada
@evssv, what size engine are you running? DDM's site says the big bearing set is for 62cc or higher engines so is it better for me to go for the light weight ones? Maybe adjustable with the plastic inserts because I have them on my current hpi hubs?
Is the big bearing ones overkill? I only have the stock 26cc and maybe max it out to 29cc in the future. Also concerned about the excess weight of them.
Z.hb71
Build Thread Contributor
Illinois
I say get em. You never know, maybe one day a big bore will land in your paws!
Portland, Oregon
Hostile created these rear carriers well before there were any "big bore" motors larger than 32cc. To date, there were never any actual problems with the stock carriers.
I say if you want em, get them. But there's really nothing wrong with the stock carriers. I wouldn't buy a set until I've broken the stockers. And I haven't done that yet.
evssv
Bristol uk
in baj atm is a scott finlay g32 mx pro👍
