Mick Boomer
- Thread starter
- #21
Do not get ceramic bearings ever. Obr will even tell you that. Unless you plan on rebuilding every race like top fuel dragster nhra guys do. Stick with nachi and stock seals.
That’s good to know wasn’t sure they were worth the extra costDo not get ceramic bearings ever. Obr will even tell you that. Unless you plan on rebuilding every race like top fuel dragster nhra guys do. Stick with nachi and stock seals.
I’m doing all the carbon also just not the chassie and a onroad build with brp mini pins blackbone 2 speedThe only reason I wanted a balanced crank is because ill be running a carbon chassis. I don't think carbon will soak extra vibrations like aluminum will. I believe aluminum is more rigid.
get uber. with the 34 reed your gunna be spinning like your on ice with the hostiles. ive tried both amd ubers hands down winI have a brand new set of hostile mxt but im eyeballing uber super spikes.
But you’re not using a obr 32ss with balanced crank so mine is different
Just run it ......I did since I built my baja and it was goodHe wont touch it since there heat treated. Im mad. Even offered 75 bucks
