Z's HPI Baja PT:2
Have you tried tape on the inside to keep them from swelling too much?
I swelled tires up as flat as a pancake on my nitro ,but the tires were glued ,they are glued to aluminum wheels an
it is hard to glue rubber to aluminum as it don't stick too well ,I had to use weather stripping adhesive to get them to
stick ,an they swelled flat an held up!
The tape will not stick to the new foams, I tried to tape em but no luck. I doubt they will explode tho, they are much better quality then the last ones. Zip tires were a just in case move, but apparently they didn't work ?‍♂️?
Loose grass on it, it's perfectly fine in person ?
Years ago ,I had to work on a greasy truck ,I a pair of brand new $ 75.00 Reboxs shoes on an they were white ,I had
got grease all over them ,but found some stuff to take the grease out ,it came in a tube ,it was called Dijji 14 I think ,
it was a white gritty paste that you rub in ,stuff was like magic ,it took it out an the shoes looked like they never got
anything on them!
If you can find something like that stuff ,it should come out some!
