Lets build a T.L.R. 5b
@Whoduh dose look a bit short....silicone tube on the end will fix that!
now the battery, was surfing the net and saw somewhere .....cant remember where:unsure: this guy used pins bolts no heads. so he had put pins were the bolts go and used Velcro straps round the battery box. put the lid on locate it tighten the velcro. wanna put a lipo in and a fire in the box with the pipe on well its not ideal. the pipe is not easy to tighten coz of the way the header sits so won`t wanna be taking it on/off. ill have to trim the body round the pull start opening but it no big deal(y)
hello so iv had a go with the spray cans. just a practice run coz there will be no going backo_O:eek:
didn't think it was all bad for my first try
don't mind the bit of tape i didnt take off on the right and have decided i need white to back the green
after i sprayed the back round green went darker than i wanted. see so those annoying food containers/lids
from the deli counter do have other uses:ROFLMAO::LOL:
ill certainly try a few more time before i commit to painting the body
while im waiting to get my servos lipo ect. thought id do a little DIY.
found some old ally junk that was taking up space:rolleyes::D in the outside shed and set to work
made a template out of old cardboard biscuit box the grinder and a square
wheel off to size her up:D
my high-tech spray booth
thought mat black would do the job
ounce they were dry thought it looked pretty cool:cool:
they have i bend in them so they sit nicely under the lower arms
didnt want to drill the arms so made the holes 5mm and used cable ties (y)
a view with the tire back on
finished up by mounting the wing. hope you enjoyed my MOD
