TLR 5b basher
If you get the killer rc batter you will have plenty of space to fit your killswitch and the buzzer that comes with it inside of the battery box20180901_180351.webp
Life batteries are another option...I've never used them before so i don't know much about them....other than they wont explode into flames on you like lipos will:eek:
not even 20quid for the pair :p
@evssv thanx for that but the killer will be 1200mah more for 44 quid also happy with having just the one battery over two
To add to that....it has a higher capacity than the stock 5ive T battery (5200mah vs 7200mah) and the killer rc is cheaper too.
thanx for that @Whoduh
@evssv you have this on your 5t do you need inner foams.......im sure you would.....correct me. want to get from
they do not give an option for foams? do the come with foams?
hey guy and gals:cool:
took my 5b for a bash session to day(y)
what a thrash!!! did have i few come to light
1. thinking about signing up my rig to gymnastics class coz hell it dose good cartwheels :LOL::ROFLMAO::LOL::cool:
2. it thinks its a dog!? kept on rolling over for a belly scratch:p
3. all the fun and games i got melt on my body:cautious: not real bad but .... any how
so i trimmed the melt away(y)
ill try and up load a vid
https://ci-45354892532-69e1dd4d.htt...2532_1080p&s=d5edf8b64970ced0328723a244eb29ce
bath time:D
I don't know if the Bart pipes are hand made, but I knew/saw the booster pipe touching the body in those places prior to every turning the thing on and i didn't do anything about it...I could have wraped the pipe or painted it or heat shield...I did none of that...so i have the melted spots that I have to cut out.
Lesson learned.
Proline makes a body for the 5ive B. The stock 5ive B body is almost double the price of the Proline.
Proline body
http://www.davesmotors.com/Pro-Line-3500-17-Pre-Cut-Elite-Clear-Body-for-5ive-B.html
Losi stock body, you know what that looks like already...
http://www.davesmotors.com/TLR250002.html
I might have to thrash the daylights out of my original TLR body and get this(y)
so im about to take the rig out for a bash ......i was giving just checking things over and i noticed mt one front wheel has bee catching on the steering rod end:mad: ! the beadlock so i took of the wheel, and its only the one. anyway took it of just to nip up the cap screws. that did nothing to help? put nit back on. there is a lot of play with the whole steering (linkages bellcrank ) i suppose a bit of give is good?
my work shop assistant lending a hand:LOL:(y)
do any of you clean and reuse air filters? i have got a few extras and the one im using is not totally
s@#*ed up. just wanted to hear from you lot
so far this has been the WORST!!! part
whos idea was it any way? FIND HIM! make sure he feels a world of PAIN!:mad: :LOL::LOL:
got the tire glue out mmmm lets just say wont be getting an A on this one
i think im gonna get some beadlocks
this has come back to bite me in the A___S went out today put on the tlr rims ..... lasted 2 mins tops
another thing cropped up lose exhaust bolt couldnt work out were the black oil spatters were coming from
since iv been running my rig i have only charged the lipo once. after about 40 mins if i tried to use full throttle
or full brakes the killer bee started to kick in??? anyway came home put on charge. ill see what happens next time
DISASTER!!!!:mad::oops::cry:
was out on a bash things where going great :D found a spot to do jumps having fun, the i noticed large blobs of.....
oil on the pinion cover:oops::eek::rolleyes:
so got home and started to take out the center diff
diff oil everywhere
the screws had started to back out on the diff cup:confused: guess i did not tighten enough
90% gone!! and no one here has the correct weight oil (15000) can only find 10000 here:cry:(n)
well suppose its all part of the fun. ill have to place an order with ddm get more and fast
so got my stuff today 15000 wt silicon diff fluid possibly the only on in south africa:cool:(y)
now i can put my rig back together (y) check out the label on the tube i bought its so old:eek:
well its a good thing im not pregnant coz the warring on the label is pretty rough!o_O
also solved the problem of the wierd angle on the exhaust header(y):D bought an old alen key cut it down with an angle grinder
and result!!(y):cool:
each head bolt had a 1/4 turn in it:oops:
you are going to have to take the pipe and or motor and pipe off the truck in order to access the battery box....
@Whoduh on a side note what i found with the battery box lid , i have only been using three bolts. the one right at the back of the car i cant reach with the allen key left it out. im sure that its all good with one missing:cool:(y)
so no removing bits to get in;)
I wouldn’t worry about the warning. Everything is a cancer causing pollutant in the eye of California. Check any store ... it’s the only state that does that. Lawn mowers at the local Walmart in Pennsylvania are stamped “ not for sale in California”. I’m surprised they sell and allow people to own cars.
Moral of the story... fill the diff and have fun!!!!!!!!!!!!!!!!
Sent from my iPhone using Tapatalk
