TLR 5b basher
Guad admit GRRRRR ! Could be not work out why I was getting oil on the outside ot the bartalone pipe. Gonna see if I can have it fixed...... . Hope so would have to have it re chromed........... guad hope so
Um there is no penetration in that weld. Looks like it was brazed and very poorly at that .If that's a Bartalone I would email pictures of that to them and say what the F*** . Did you buy it From them or DDM?
This is also why I don't like chromed pipes it hides imperfections and bad welds. Chromed pipes are usually just welded steel or in Rovans case Aluminum or tin not quite sure . I prefer raw Stainless steel or TI . Granted they are more expensive.
after a long wait i got my rebuild kit from OBR the other day. so to today i stripped the top end off ?
put a new head gasket and while i was there i put a new piston ring? took some pics along the way.
can see on the left where the gasket was blown oil all on the bell housing?
50371
the old head gasket can see where it was leaking
50373
the new ring cleaned the block off with a razor
50374
got to use my new torque wrench(y)
50375
now maybe the issues will go away:unsure:(y)
cool. hope its good now and don't happen again (y)
so i had all the good intentions to go out with the losi today:)
got all amped cut some new hole in my body for some extra air flo(y)
got out the worlds smallest angle grinder disc marking pen and set to work.
things were all good for about 15 mins and my pull start snapped ?
took some pics??
50589
50590
50591
50592
50593
bought some new silicone tubing for the exhaust coupler. found a car shop sell it works really well
50594
50596
on the plus side coz its been quite muddy my rig got a good clean???
50598
took some pics??
Looks BADASS man!!!!
looking good doug. (y)
I want your wheels!!! :ROFLMAO:
so did you not even get to run it?
get some they are the losi stock bead locks(y) they are the v1 new ones v2 are slightly different
got some cord redid the starter pulled my air filter washed it and the spares
now just to re oil and try again tomorrow
50600
50601
next ones are for jimbo?;)
50602
bottom one was just in my rig.....could have been over oiled:unsure:
50606
50604
all clean for the next few rounds?
50607
