TLR 5b basher
dougstar
KZN South Africa
was at a new park today had a bit of a run wasnt without issues:eek: flipped the rig sideways bigtime and both shock mountings on
the rear lower arms poped off
51915
51916
was an easy fix back in the car(y) then flipped it agai nearly landed in a creek:eek:🀘 lucky it was saved by a big root(y):cool:
51917
cant see in the pic but was down a bank:eek::oops:
dougstar
KZN South Africa
Wish I would've read about your manifold issue 6 months ago.πŸ˜ƒ I have an aluminum manifold in my to do box for the Losi. Guess I waont be putting that on.πŸ‘ŽπŸ½
Honestly the obr ran so bad with it πŸ€”πŸ‘Ž few months back when i was having hassle with my motor , i was chating with sean oneil . he had said to me that he'd change the manifold coz they give sh!teπŸ’©. at the time i thought .....well seans just trying to trouble shoot and past it offπŸ€” then about a month back i was running the losi and felt
the manifold and it was hot to the touch. And enev thought of putting on a new 1107.....glad i did notπŸ‘ change back to stock intake and she runs like a dreamπŸ‘. So yes don't put it on. It may work ok on a baja πŸ€” that get lots of air..... but ill never use one again!
Frenimy
The Stock Zenoah manifold can and will crack or warp at some point. The billet manifolds from OBR are cut shorter than a stock Zenoah and are meant to be run with a phenolic spacer block to isolate the heat from the motor to the carb. Some of the other billet manifolds are not built this way and can warp with excessive heat or cause issues with the carb as you have experienced. I will always run the OBR billet manifolds especially since I have seen so many stock manifolds break and warp.
Frenimy
The DDM intake is junk look at the others that actually have a 1/4in or more of phenolic spacer to actually isolate the heat from the carb. If you would have run the OBR intake and some some knock off you would not have had any issues, simply user error in this case. Buy quality and buy once or cheap out and redo it several times.
dougstar
KZN South Africa
Thanx it was a good runπŸ‘ car ran so smooth with the stock manifoldπŸ‘
Ill never go back tok a billet one. now just to tackle the shock issue ........but not worried about that πŸ‘
If i had the droop screws ajusted further in my shocks perches probably would not have popped offπŸ€”πŸ‘ hope that the new irp upgrade sorts this outπŸ€žπŸ‘
dougstar
KZN South Africa
Just did a rebuild on my shocksπŸ‘πŸ» I upped the weight of the shock oil from 40 to 45.
I just recently ordered some irp shock purches and put them onπŸ‘πŸ»52418
52419
52420
My hitech shock standπŸ˜†πŸ‘πŸ»
52421
52422
TLR shock have bleeder caps this makes
The rebuild a walk in the parkπŸ‘πŸ»
52423
I had two bottles of the 45wt oil not much
Is left of the two bottlesπŸ€”
52424
52425
Dam those look good now no more shock
Poping offπŸ‘πŸ»
52426
dougstar
KZN South Africa
MOD Ultimate Rear Diff Inserts Losi
52452
this what they have to say about them on the DDM page(y)
ADVANTAGES:
Much Larger Bearing to help with extreme load. Lasts much longer then standard flanged bearing. This equates to less maintenance cost over time.
Improved Geometry, as now its less likely to strip gears as the OEM right side diff insert is undersized and allows diff to move fore and aft in the case causing improper pinion / ring gear diff engagement which can cause failure to occur.
Improved clearance to run boots over the outdrives. This will help refrain from bone and outdrive wear.
Been in Matts Cars for over 3 years, with success after success with less maintenance cost over time
MOD INSURANCE POLICY:
Ultimate MOD Rear Diff Inserts $63.99 > $64.98 Replacement Ring & Pinion (not counting countless bearings you wont have to replace and have to empty your diff oil continuously to reach the left hand bearing ($27.98 on average to rebuild bearings/oil) (View second image for parts breakdown)
FEATURES:
7075-T6 Anodized Aluminum
Avid RC Bearings
100% Made in the USA!
