- Thread starter
- #301
the rear lower arms poped off
was an easy fix back in the car
cant see in the pic but was down a bank
Thanx it was a good run? car ran so smooth with the stock manifold?Nice man, good times! ?????
Honestly the obr ran so bad with it ?? few months back when i was having hassle with my motor , i was chating with sean oneil . he had said to me that he'd change the manifold coz they give sh!te?. at the time i thought .....well seans just trying to trouble shoot and past it off? then about a month back i was running the losi and feltWish I would've read about your manifold issue 6 months ago.? I have an aluminum manifold in my to do box for the Losi. Guess I waont be putting that on.??
This is what I was running from DDM it sux and made my obr run like Sh!te?cut shorter than a stock Zenoah and are meant to be run with a phenolic spacer block to isolate the heat from the motor to the carb.
If i had the droop screws ajusted further in my shocks perches probably would not have popped off?? hope that the new irp upgrade sorts this out??Thanx it was a good run? car ran so smooth with the stock manifold?
Ill never go back tok a billet one. now just to tackle the shock issue ........but not worried about that ?
