Your going to have a literal ton of money sank into this fyi. The Rc max stuff will be about the best you can get. And watch your mtxl to dbxl crossovers not everything fits. And its gonna need some decent power to keep it motivated. They are on the heavy side with those big arse tires. With brushless your going to have to gear it rather low to keep the motor from over heating. I would reccomend something I the 8S plus range for starters. That should keep you in the lower end of expensive with ok run times. Start a build thread if you choose to go the built from scratch route. I'll be following if you do.?
