Bryan K.
So I purchased a King Motor Fuelie 30.5cc motor for my DBXL. It came with a Walbro 997 carb and I can't figure out what's wrong. Each time I'm able to go through about a tank of gas before the piston shatters into a million pieces. The head is in good shape, so maybe the pistons are just bad quality. I run 1 1/2 turns out on H and 1 1/4 turns out on low for the carb. The entire time the car runs like a champ, no odd noises or any hint of running lean. Perhaps there isn't much smoke at full throttle top end, but I thought maybe that's normal. I know my Baja smokes quite a bit a top end.
Anyways, after rebuilding the motor with new pistons, head, crank, etc. and running through 2 pistons with the exact same problem, I chalked it up to just bad quality parts from King Motor. So I purchased a mint 29cc CY motor off a friend of mine. It's a 2 bolt head, but loads of compression and it was pretty new. It didn't come with a carb so I reused the Walbro 997. Anyways, threw this on the DBXL and it ran for about 3 tanks this time before the motor died and wouldn't restart. The motor was very tight. I could still pull the pull start but I noticed a lot of resistance when the piston moved up into the head. I currently can't pull the head off but I took everything else apart and I could see on the carb side the piston has some massive gouges. The piston on the other side looks brand new and there isn't much scratches on the walls of the head. Any ideas as to what's going on? I'm getting tired of pulling motors and rebuilding them. Maybe the carb is junk and leaning out my motors? The plugs look fine each time I pull them.
I also attached a pic of yet another motor I'm about to install. This is a 30cc 4 bolt CY. Before I run it again, I'm going to get a Walbro 668 and see if that changes anything.
thanks,
Bry
thanks,
Bry
