Z's HPI Baja 5b/5t build
Status
Not open for further replies.
Alright so I went to start it and there's no spark, so it wouldnt even cough (obviously), so there's a problem to be resolved, as usual lol. Even unplugged the ks and nothing so there's something up with the coil
gapped properly and all that jazz?
And BTW, no, the Shredstack will not work with the Uni filter. It's designed to work with the stock HPI filter housing. The ring from the filter assembly clamps everything together. I have one an will be happy to take some extra pics so you will be able to see what I mean if you want.
Make sure the cap and the ht leads are all sweet? theres like a copper coil thingy connects the two?
Double checked the connections to the coild, off switch, and ks lead all is good there I think. Gunna check the plug lead and if that's fine then the coil is faked ? not too upset if that's the case, cuz were early ?
Nah look at 11:36. Gap looks too big to me, but ok. When I do it I put the flywheel magnet directly under the coil with the gap tool in between and pull down on the coil while tightening the screws but if your good then I'm good??
Status
