Won't idle
Keyway looks fine, so does the key. It was also running fine after I put it back together after the flywheel fell off. Maybe detonation? Didn't bang a hole yet in the piston so that's good if it is detonation.
Detonation makes a sound btw? Didn't know that
More of a knock in fullsize engines. I dunno what it would sound like in these.
If your worried about loose bits internally Im not sure I would. If something came loose you would know it right away. It would show obvious signs of damage somewhere. I cant picture a scenario where metal is bouncing around a running engine without major issues. You could always split the case and check if you want. Gaskets are cheap too.
Googled it, it's a ping or knock sound. This kind of sounds like what my engine was making. It might be detonation ?‍♂️ hopefully I haven't feked anything up if it is.
Apology for scolding me accepted.?
That's what I'm thinking, a circlip coming loose and going through a port and falling down the case without hitting the crank or wedging itself in a bearing and not damaging anything is like a 1 in a million chance. When I jiggle the motor around in my hand I can't really hear anything flying about in the case. Splitting the case is an option, I'm not sure if I want to do that tho. Its good practice but it's alot of feking work
Well, it is a expensive engine. Might be worth it. You've already torn into it this far so ?‍♂️ or slap the head on and see if fresh gas and plug fixes it. If the engine fell apart OBR should warranty no?
Idk if they will . They say 90 day warranty but I haven't ran the engine till like 3 weeks ago. Head isn't off btw. It's still on
Have you figured out if you were piston slapped?........:giggle::giggle::giggle:
Well Z, if it makes you feel any better, my dbxl is running sweeeeet. The tune matched up perfectly to the atmospheric conditions, and she took off like a guy running from you? and heres the kicker, it will still work next time I fire it up.??
Now that I got that out of my system, did you dig in or what? Find anything?
Yeah I took it all apart (not the engine, the car, I am not taking the engine apart, if there's a internal problem it's going right back to obr) and nothing was loose or fekd up, regapped the coil ect.
