Yours lasted about as long as my sig series. I think I'm done with OBR for a while.Yeah it's really poopy ? we'll see what happens with it when obr responds
Totally different issues but I get what ur saying. Mine has less than 3 hours , I don't think this is.my fualt. It was running hella rich, just lean enough to get it to rev out. It is quite dissapointing , especially for a first experience with one of their engines.Yours lasted about as long as my sig series. I think I'm done with OBR for a while.
Grass clogged the air holes on the case. It overheated and destroyed the top end.@crucialRC refresh me.... what happened to your sig series again?
Yeah your reed is feking awesome ?my reed motor is the bombpiston port has had issues and with the way thing are now with the twin.............ill just have to see how i go forward with OBR?
surly OBR not to blame for that though?Grass clogged the air holes on the case. It overheated and destroyed the top end.
Yeah I don't blame OBR for crucials issues. That could happen to any motor. I don't give a fek what happens that much. I just want my rig running againsurly OBR not to blame for that though?![]()
I didn't??Hmm... forgot about that
ALRIGHT! I've found something. So I noted my pullstart wasn't catching, which was odd as the pullstart was fine,and the flywheel was fine. So I took the flywheel off today (previously I didn't take the flywheel off, as it is a female dog to do, and I thought since the engine turned over by hand, it was fine), well not so fast. I took the flywheel off, and the key fall apart in 2 , and the flywheel is cracked as fek. So , that might be why it was clanking. And that's probably also why it wouldn't run or just run like dogshit, becuase the timing was well feked
I hope I haven't hurt it by trying to run it like this.
We'll see, if I get a new flywheel and key.that will do it![]()
Me too. Hope I haven't feked anything internal. Im Gunna show Sean at OBR and order a new key and flywheel and see what happens.When I watched your vid ,it also sounded like something rubbing ,I heard that more than a knock ,
but any way ,that is good news an hopefully that is all that is wrong with it!...![]()
Damn right it was ???????????bet that was y clone flywheel![]()
