Ur problem isn’t the oil. It’s the springs ??
K think the ddm springs will be in order ?Yes I need to up the springs on my bajas the stock irc spring suck??
Looks good, I see your used to holding small things in your hand, the screw driver I mean ????Good run today, at the end the steering link backed off (just unscrewed, no breakage) but I still ran it,did about 20-25 mins ??
View attachment 59392View attachment 59393View attachment 59394
Think my filming skills are improving
The shocks are far too soft for off road I'm gunna put thicker oil in it. Probably 50-55 weight. Got 40 in it atm
Yeah too used to giving you handjobs ?Looks good, I see your used to holding small things in your hand, the screw driver I mean ????
Yeah but metal are feking experience ?? 40 for a ddm steel gear . IPlastic gears suck??
Brand new bearings ,came with clutch housing. Well I definitely was landing on throttle, not really big jumps tho.How old are your clutch carrier bearings Z? In my experience the plastic spurs only really let go if the bearings are done or big jumps landing on throttle
