- 27,691
- Thread starter
- #1,561
I'm gunna blame the axle pins on me running them dry (no grease or boots). The spur idk why it's feked. For now I will just get another and run it while I save for a metal one. I know I'm transferring the weak point else where tho. Guess off to ddm I go ???
Actually you may be on to summin, the stock chassis is flimsy as poop. Might make a brace. Idk if that's the problem tho, I'll check it out. Could've been flexing when I hit the few rolls,cartwheels, or small jumps idk.The metal doesn't give ,so any jamming will transfer the damage to the tranny!
Also ,when you install a more powerful engine ,maybe need to fabricate some kind of engine brace to keep
it from walking around on the chassy ,causing the gears from jamming!
