cardarear
Would anyone like to play the "it won't start game"? So here's the deal. Engine was starting and cutting off a week ago and no it won't start at all. Probably my fault but I can't figure it out. So here's what I've checked it noticed.
I can't see the spark by grounding plug to the top of the head but the tester does light up.
Tried 3 new plugs
Replaced ignition coil
Tried with and without kill switch wiring
Checked for correct spark plug type and gapping
Mixed fresh fuel (28:1) in case spark not the problem
Checked for flooding by removing carb and also turning upside-down with spark plug removed.
There is fuel in bulb and return line and plug comes out wet.
Carb and air filter bolts are on tight
Bolts from head to crankcase are tight.
Breather hope in gas cap is clear.
Air filter is clean ( vehicle always runs with all three outerwears)
I would check for compression but not sure what I'm looking for.
I've already sent an email to OBR for help but does anyone have a suggestion for something I should check?
Tried 3 new plugs
