- Crafers South Australia
HEY ? What's wrong with base 1107 settings ?????
??not dougstar settings
I’ve heard of ppl having issues with those quick disconnect pieces. Try to run it without them ??
I tried carb off and fuel directly into the cylinder. Admittedly the wheels were on the ground. It didn't even try to fire. I also did a compression test and got about 110 psi. I ran out of ideas. The engine is on its way to OBR so they can take a look.First problem is Those quick connects, I have many engines and attempted to use those on an obr Reed 32....to no avail they were chocking the fuel delivery....remove them....
next take carb completely off drop in a few droplets of fuel with plug in. Raise vehicle “Wheels up”....it’ll start and rev high as hell for about 4 seconds then die...This is how to unflood engine.
next put carb and gaskets back in place with out quick connects ...good luck....
Yes, I did get another new plug. Well stock carb setting for the low on 990 is 1 1\8. I normally run between 1 and 1 1\16. But when I have trouble starting, one of the first things I do is reset it to stock.?I didnt read that you replaced the spark plug after you found the wires were not connected to the coil and you seen the plug was wet. Did you put a fresh plug in after that was found? I still think it is carb setting being too rich on the lsn
