G340 full mod won't start
First problem is Those quick connects, I have many engines and attempted to use those on an obr Reed 32....to no avail they were chocking the fuel delivery....remove them....
next take carb completely off drop in a few droplets of fuel with plug in. Raise vehicle “Wheels up”....it’ll start and rev high as hell for about 4 seconds then die...This is how to unflood engine.
next put carb and gaskets back in place with out quick connects ...good luck....
I tried carb off and fuel directly into the cylinder. Admittedly the wheels were on the ground. It didn't even try to fire. I also did a compression test and got about 110 psi. I ran out of ideas. The engine is on its way to OBR so they can take a look.
?I didnt read that you replaced the spark plug after you found the wires were not connected to the coil and you seen the plug was wet. Did you put a fresh plug in after that was found? I still think it is carb setting being too rich on the lsn
Yes, I did get another new plug. Well stock carb setting for the low on 990 is 1 1\8. I normally run between 1 and 1 1\16. But when I have trouble starting, one of the first things I do is reset it to stock.
Based on his 110 psi compression, I'm guessing the piston / cylinder were scored. Unless he didn't use a proper small engine compression gaugeto take the reading.
