My man is doing some serious bashing??
Idk if you can call small jumps and rolls Serious ?My man is doing some serious bashing??
Wheel nut is my fault, front bulkhead cracked when I smashed that damn curb, top plate has been rebent like 3 times , hosile axle boots shredded for no reason, shock shaft bottom ripped out form Bering worn down I assume, foams blew out cuz powaaaa, front arm has always been cracked and it's kinda poopy.See the wear on the arm
Should I replace the arm while I'm at it? Got a ton of poop to buy . I've got some money And I want to fix all the hacked poop (wheel nut, cracked front bulkhead, maybe a new top plate for the front, axle boots, shock shaft, foams for the tires, front arm has a crack)
The road probably. My suspension was set way to soft so it probably bottomed out a few times and scraped that plastic awayWhat chomped the arm???![]()
Actually dude your 100% spot on. My Headass put some self tappers in the wheel and they potrude and were definitely wearing the arm an shock when they bottom out ?Nah guy it's not feked on the under side .... looks like the rim imho?
Actually dude your 100% spot on. My Headass put some self tappers in the wheel and they potrude and were definitely wearing the arm an shock when they bottom out ??
Need to take those out and put the right size now ??
100% my fault ?literally only something that would happen to me ?
This poop is gunna be Feking expensive ? need to fix it up, cuz tis hacked together as fek and if I'm selling it I don't want to give someone it like this ?GETO STYLE RC GROMMET CLUB????
Just keep playing videos of Losi's Running!And I'd like people to know. I'm pretty much set on doing a Losi ?? my mum isn't so pleased ("you just built it" and all that) so that might be a hangup but I'mma try for sure ? she usually isn't too hard to convince ?
Yep or do a hybrid if I wanted bigbore (like reviving Frankie) ? so I think it's a good move.Honestly, I've had my fair share of breakdowns with the HPI, but I've never seen anyone deal with these kinds of issues on a daily basis.
To be frank, I think getting the Losi would be a good step for you. It's a model that's pretty bulletproof out of the box and doesn't require a ton of investment in durability as you play. You just get to enjoy it.
At this point, you need to get your running vs. wrenching ratio back closer to center.
If, in the future, you want to play with another 2WD, you can always lock the center diff and disconnect the front drive.
Right after I broke this time , an I told her I got an $84 repair bill I said "see, this is why"she might get it now ?Just keep playing videos of Losi's Running!
She'll get the point (Especially with you complaining and moaning, [More then usual?] how your rig don't work and along with all that money it's gonna cost to fix).
I say, it won't be long before your in the losi club.?
