Z's HPI Baja PT:2
K so I've put it back together. First I changed out the bellcrank with the new one
Then I added the lights. So they were not a bolt on affair, ad they came off a Losi and not for a Baja , so what I did was I made a little plastic plate and screwed that to the lights, and then the plate and lights to the bumper thingy . Maybe alot of effort for just the light buckets but I think it looks great
After that I did the shocks. Changed the springs around for the stock lower ones, and the ddm harder upper springs to give that a go. Aswell as I changed from 40wt to 37.5wt and we'll see how that goes.
That orange is fugly but way to lazy to de anodize ?
Shox installed
Done ?
Did that ? chew a hole in your electrics lid? How the heck did you break that?
was off the 70cc baja, the bunch of holes were different attempts at mounting the cdi , killswitch, ect. never replaced it, but i should cuz its feking ugly.
how do you work on your rig while its dirty like that? were you raised by wolves?
im not a pussy like you is how :LOL: j/k. couldnt give a fek. my hands will get all dirty either way. and cleaning isa waste of time cuz its gunna get filthy in 10 seconds anyway
for the record, everything i changed was i made the suspension softer in the rear (37.5wt, different pistons, stock lower springs, ddm upper springs) and changed my toe plates from 3 (degree?) to 1. so we will see how it reacts and how i like it.
Im with you Z. RC's are for using, not cleaning. don't let these sissies get you down Z.
you can’t argue with a man that means business
