Crucial Baja Dragster
Got some more wrenching in today. I've hit a speed bump tho. I need a few parts and I have to rip the 2 speed out of the primal to put in here.
Aluminum Rovan hubs. Had to shim the fuk out of the BRP adapter.
Front shock delete on. I have to figure a way to fill the space?
Blackbone gears
Vertigo monster locker with Uber axle kit
Not a fan of the gunmetal. I went a different route since I bought this. I may get the black case and sell this one. It's just mocked up for now. I have to go back in it and put the 2speed layshaft in it from the Primal.
Supposed to be clip on shims on the front end upper arms??
Not with rpm, rpm eliminates that. But he should reuse it now that he has no front shocks.
View attachment 69649View attachment 69650View attachment 69651
View attachment 69652View attachment 69653
Blackbone gears
View attachment 69655View attachment 69656View attachment 69657View attachment 69658
View attachment 69659View attachment 69660
Looking good crucial, top notch build as always ?
Thanks Z. The clip on shim is too big and it looks like the shims should be centered and not sure what to do about at the bottom where it mounts to the arm?
Progress. Actually glad @spents said something about the rings cause I thought I could install from outside but turns out I had to pull the cups to install the rings??‍♂️ Waiting on parts to finish now.
This for the front end View attachment 69662
Do you have a part# for these?
