Dean makes awesome gear??
Not with rpm, rpm eliminates that. But he should reuse it now that he has no front shocks.Supposed to be clip on shims on the front end upper arms??
Looking good crucial, top notch build as always ?Got some more wrenching in today. I've hit a speed bump tho. I need a few parts and I have to rip the 2 speed out of the primal to put in here.
Aluminum Rovan hubs. Had to shim the fuk out of the BRP adapter.
View attachment 69649View attachment 69650View attachment 69651
Front shock delete on. I have to figure a way to fill the space?
View attachment 69652View attachment 69653
Blackbone gears
Vertigo monster locker with Uber axle kit
View attachment 69655View attachment 69656View attachment 69657View attachment 69658
Not a fan of the gunmetal. I went a different route since I bought this. I may get the black case and sell this one. It's just mocked up for now. I have to go back in it and put the 2speed layshaft in it from the Primal.
View attachment 69659View attachment 69660
Thanks Z. The clip on shim is too big and it looks like the shims should be centered and not sure what to do about at the bottom where it mounts to the arm?Not with rpm, rpm eliminates that. But he should reuse it now that he has no front shocks.
Because he already has the dex rc shock eliminatorsWhy cant you just stick a turnbuckle in place of the shocks up front? Or am I missing something ?
I just ordered a black TR.What trans case are you going for now
Do you have a part# for these?This for the front end View attachment 69662
