- Nj
Standard= cheaper. Like I said I modified mine with bolt on parts and its been good to me.
Spents your the man. ??i have a killer roto start miles and they are decent, but be aware the one way bearings do fail sometimes in the driver part, they can be changed but pain in the arse, always have a spare driver part with ya if ya get one ,
i've tried most pull starts as well, i had a zenoah pum pull start on the twin and that was mint, right up untill it starts to wear, then it eats the secondary springs, tr pull start is total wank imo, never could get mine to work right and it ate the secondary springs all the time,
the rofun/zelda/spovan 45 has an ezi start on it and tbh thats quite nice and smooth, but heard there are issues with em and they need a slight mod to the pawls, but that wont fit your engines anyways,
i just fitted a full size alloy ezi start pull start to the twin ( its a chinese version but is well made) instead of the zen pum one, juries out on that one at moment till i get the dragon hammer finished and up and running again, but its smooth, but also had to mod it a tad to get it to work on the twin,
the fid ezi pull start looks good , but is expensive for what it is in my view,
nowt wrong wi normal pull starts though
reason i prefer the ezi start ones is cos , well imagine trying to start yer rig whilst being sat down and ya cant hold the car down wi yer foot,
thats me ,
ezi starts make things easier in my case, but ya needs to keep em clean, same as any starter tbh though
That looks nice mate, but I’m only using a ported piston 34 as my biggest engine for now.
Heavy straight away is no good for me. I’ve ordered the killer rc job as that looks to be the lightest. I hope I get on with it.Never had a stock zen shite the bed, but I've also never had issues on any of my saw starters as well. For what it's worth the fid starter is pretty good. Shipping is slow and its heavy as fek. But it lasts.
For a big rig that’s absolutely fine, I’d consider it for my bullet proof tank build but not for my Bantamweight job.Call me lazy but I'm liking this setup more and more
https://www.ebay.com/itm/wolunstart...c-starter-E-start-for-1-5-RC-car/303709806875
TR JUNK , ROTO START JUNK. Sand got in the roto start and locked up the one way bearing on my OBR and destroyed it . The TR on the same motor only lasted a couple of runs. I didn't pull that hard on it .The spring inside is the weak link.Hey all,
Are FID or TR pull starts worth it, are they any good and are they much heavier than stock. I’ve also got my eye on the new easy start by RCMAX but that looks chunky and heavy.
My preference would be a roto start but can’t find one anywhere.
Please let me know your experiences?
Cheers,
Milo.
I too had similar p/s issues with my cheap Rovan, fine sand grit clogged and siezed the spring tension centrifugal pully pawls and after about an hr of bashing my p/s did not p/s. I was pissed. I wish there was an adaptor mod to run a quality chainsaw p/s on our 1/5 engines. Those designs almost NEVER fail.TR JUNK , ROTO START JUNK. Sand got in the roto start and locked up the one way bearing on my OBR and destroyed it . The TR on the same motor only lasted a couple of runs. I didn't pull that hard on it .The spring inside is the weak link.
I bought a used 1984 CR 500 the last year for air cooled and it had some upgrades done to it. I was only 17 and probably about 170 lbs , I had it 4 days before I could even start it! I had to learn the right way, getter just coming down off TDC and kick right through it. God forbid it kicked back!Rotostarts have their place but it's not on 1/5 gas engines. I like rotostarts for nitro. Absolutely nothing wrong with 1/5 gas pull starts as long as you understand how to do the "snappy short stroke" technique . Remember 1/5 p/s's and NOT lawn mower pull starts and need to be worked accordingly. 1/5 p/s's don't have 6' of forgiving rope pull. 2 strokes develop compression every other stroke, and lawnmowers every 4th stroke. So you need to be very abrupt on the rope. A trick with a 2 stroke is gently pull the rope and feel the piston compression then continue to move the piston just past TDC . This gives you a full 1/2 rotation of non-compressing piston traveI.
Rule #1 : Never wear sneakers when kicking a 500 cc anything. Wet flip-flops are a better option.My 2002 yz426f supermoto jack hammered the poop out of my shin one day and it used to eat holes in my sneakers
I own (2) TR pull starts, (1) on my Losi 5 T and (1) on my Vekta 5.Hey all,
Cheers,
Milo.
