- 2,058
Ok seems like a simple question...with a simple solution. Reverse the servo in the TX. Well not that easy on the Raminator. The throttle is also tied to the brake servo...i.e. you pull the trigger and the throttle servo pulls open the carburetor and the brake servo moves releasing any brakes. You hit the brakes and the brakes apply and the throttle servo moves opposite direction to release and close over the carburetor. Well the Savox servo is going the wrong direction. It is going the opposite way I need it to. I.e. I hit the gas it is closing the carb...hit brakes opens carb. Cant reverse it at the transmitter as then it give me the wrong effect at the brake servo. Am I missing a simple resolution to this somewhere? How do I go about fixing this issue so I can run my new servos? Thanks guys!
