Finally got one!
So I am going to run 112 and motul 800 that was recommended by rcmax dude. Now looking at Amazon they have road racing and off road. Which one should I go with?
Choosing the right decals for this color is extremely hard. Can't decide what to get.
Carbon is part of the game, with high oil ratios, and staying in the safe area of engine tune. Lots of carbon and or splooge is a sign you need to change your tune, and or revisit the amount of / and or brand of lube. I would assume you'll see positive changes as the maxima oil, has a higher level of dispersal agents in it, over the lack of such additives( that I'm aware of) in any caster oils.
Installed the skyrc switch. Had to modify it to make it fit correctly. Came out good .
Desoldered the wires and soldered on the other direction..
Some hot glue over the wires.
Drilled the center of the bottom tray to run the wires
Installed.
