Kraken KV5TT Build
Do they have anything at MMC for the rears length in the 100# weight too instead of the 300#ers..I think that's are choice number to start and be still a little stiff
How are they going to fit on the vekta shocks being smaller?
No just coil bind weight comparing🤣..sorry I'm confusing you brother
Need mmc springs in 100# weights for front and rear.
Baja springs definitely won't fit..just using as a reference for machine weight with big bore..that a spring option they offer..I've already asked them(innovative rc) if they'd make a custom set of springs as well a few months ago just for kicks
I am going through on McMaster and you can choose the measurements but not lbs.. not sure why?
I can
Yeah i know haha but I am still going to try it.
The fronts are 98lbs load.
Fronts
116mm L
42.35mm OD
36.35 ID
coil spacing 15mm
Coil thickness 3.25mm front and rear.
Might need aluminum shock bottoms.
They should still have the aluminum shock bottoms on ebay..irp, the spring perches were one of my first upgrades
https://www.ebay.com/itm/IRP-Kraken...t-/293659842207?_trksid=p2349624.m46890.l6249
Offer $65
They are a very nice piece and will be perfect for this spring upgrade
I am trying to do the custom made to order but I have no clue how to build one that will give me a rate of 80lbs-100lbs for the back.
