- 27,691
What's that meanIst never gonna be straight again.....bit like you straight on the one side and bent as fuk on other![]()
and it's a fricken wheeliebar, big deal if it isnt exactly straight.
The feckAnd only half bent![]()
This wheelie bar should have had a second bar across the middle Mac
Be something you can mod for extra support
That would be even better mod itYeah need an X in the middle![]()
I run a set haven’t tried to remove them yet screw heads are a bit shallow. Could be a issue when you try to remove since they have loctite on them.I have a set on the twin.....and they are rcmax .......feking little bolts stripped only after one fittingso not that impressed
OiWelll. Hate to say it, buuuut told you so![]()
Guess I'm screwedWelll. Hate to say it, buuuut told you so![]()
Guess I'm screwedI even debated whether to put loctite on or not
I will eventually replace srew with socket head screws and a washer
