What's that meanIst never gonna be straight again.....bit like you straight on the one side and bent as fuk on other
and it's a fricken wheeliebar, big deal if it isnt exactly straight.
Like I said, I'm always right
The feckAnd only half bent
This wheelie bar should have had a second bar across the middle MacLook at the state of thatView attachment 75479
Propper wanked
Be something you can mod for extra support
That would be even better mod itYeah need an X in the middle
I run a set haven’t tried to remove them yet screw heads are a bit shallow. Could be a issue when you try to remove since they have loctite on them.I have a set on the twin.....and they are rcmax .......feking little bolts stripped only after one fitting so not that impressed
Oi yeah ya did tr cases not oozing so not sure......maybe the surprise is still waitingWelll. Hate to say it, buuuut told you so
Guess I'm screwed I even debated whether to put loctite on or notWelll. Hate to say it, buuuut told you so
I will eventually replace srew with socket head screws and a washer
