- 22,966
Tape
Fitted up nicely and very sturdyMan, I really like how that silenced pipe mounts compared to the non silenced samba. Looks great!![]()
Ya, for silenced it is pretty loudGotta change your share settings for your youtube vid
Says private
You got it
Damn that silenced pipe is still pretty loud..can't wait to hear it really sing.
Another short vid man this motor starts so easily but I need a toe rope for this monster before I decide to really take her out and run herYa, for silenced it is pretty loud
Hm someone just recently posted about the same issue @blackrain ....can't remember who... I still would suggest full metal lock nuts and or drill the nuts and studs you have and lock wire it yourself
I did the studs with a lock washer and nut the nut ddnteven come loose but the whole stud backed out. I did use blue loctite going to switch to red. But I think due to the heat of the motor might not make a differenceHm someone just recently posted about the same issue @blackrain ....can't remember who... I still would suggest full metal lock nuts and or drill the nuts and studs you have and lock wire it yourself
Lock wire might be itI did the studs with a lock washer and nut the nut ddnteven come loose but the whole stud backed out. I did use blue loctite going to switch to red. But I think due to the heat of the motor might not make a difference
I likeI just passed by something yesterday at the auto parts store it was a high temp red loctite. I'm not sure what Temps you would see at the exhaust port but maybe try a high temp copper silicone as a loctite of sorts just to help bite the stud
Hi, where did you get this "screw" for the brake disk from? how does it improve the brake performance/life? Nice setup by the way!Yes
The 0 ring that came with new shaft is so thick brake can't move over itView attachment 75528
Thanks, if your speak about the piece that holds the brake plate centered . That came with the vertigo transmissionHi, where did you get this "screw" for the brake disk from? how does it improve the brake performance/life? Nice setup by the way!
