Nice it should have come with an lsd in the center unless the 2 speed requires a one wayHere you gofeking awsome
Got rally wheel setup ......it huge
as far as I can tell the center diff is a one way. If I lift it up and hold a set of wheels it locks going backwardscouple perv pics
View attachment 76210View attachment 76211View attachment 76212View attachment 76214
I’m pretty sure the lsd acts the same way. I’ll check for you when I go outsideIf spin the center diff gears backwards there is no engagement, spins freely.....
Got to be a one way difff![]()
You can get the pro with front and center lsd for about 1950This really makes me want a w5. Not sure if I'd want the ultimate though or just the pro version
his XR5 come with 2 speed opt so it will need that one way diff in center not our LSD center diff bro@DougStar should have these markings on the case. Also I just checked the mcd website, and yours should’ve came with a center lsd. Same part# as mine. I think the 2speed gear is an optional part
View attachment 76232View attachment 76233
Yeah that’s what Maher at cardinal just saidhis XR5 come with 2 speed opt so it will need that one way diff in center not our LSD center diff bro
after spend poop load of money on mine, i earned my knowledge the expensive wayYeah that’s what Maher at cardinal just said![]()
before you buy any parts ask me first, i may have itThere is some papper work other than the v5 instructionsmust have a closer look
sure it will tell me what the center diff is
your are planetary diff ( and i have 2 brand new as take off when i first got mine w5 )Mine doesn’t lock in either direction. I think the lsds only lock once torque is applied
I upgraded the diffsyour are planetary diff ( and i have 2 brand new as take off when i first got mine w5 )
for both or just the w5?I upgraded the diffs
Just the rr5 my w5 still has planetariesfor both or just the w5?
