ChrisBlue233
Hello All,
I rebuilt my engine about a year ago and have done some upgrades to it. Unfortunately, the aftermarket air filter I got doesn't do a good job and grass and dirt made its way around the filter foam. It took a piece off of my piston and trashed the cylinder. There are pieces of metal in the bottom end from I have no idea where. The connecting rod is also chewed up. I have an extra piston and a used cylinder but I don't know if it's worth it. Should I rebuild it to see if it even works or is there an engine you recommend? Thank you.
