- Crafers South Australia
- Thread starter
- #361
Yeah 9.5 is wheel spinning too muchYou went down to a 8k?
Learn to drive.Yeah 9.5 is wheel spinning too much
Lol this is trueLearn to drive.
And the tires I bought are medium compound......its too hard. When I bought i was lemme get used to the car first then ill get the softer rubberI agree with Doug, I have 9k spring in the vekta and it's very hard to feather the throttle to get going. Pretty much spin all 4 till it starts moving, pretty much does the same thing if you let off while moving and get back on it. The stock tires do suck pretty bad though.
Hell nah!
That’s how it’s supposed to be
You can tune the shocks without replacing the oil. If you want heavier oil use a piston with less holes if you want thinner oil use a piston with more holes.So in order to get better performance out of the xr5 . I have lowered the ride height and doubled the preload on the springs ill see if this helps with handling @Team Ninja Pro suggested heavier shock oil that will be the next step
Good plan bobYou can tune the shocks without replacing the oil. If you want heavier oil use a piston with less holes if you want thinner oil use a piston with more holes.
Those two guys are cooked
