- 58
Looks super mean! @Spirospros , why are two of your lower links black on your 4 links. Just curious.Wheel extemded base is incredible. Also the wheels wider is amazing. mine with both upgrades
Thanks Relic. That means a lot brother!I can just sit and stair at yours too !!![]()
looks much better than before. much more beautifulYeah I wasn't sure about it. Seeing it only in Primal's video I wasn't convinced I would like it. But after I saw pics of Spirospros I was sold. John I know you were gonna run beefier links and hyme joints, the extended links are an inch longer. Adding 2 inches total in wheelbase if you make your own. You will need the extended sway bars that come in the primal kit. They also said the front brake cable is extended, however it was the same stock as my stock front cable.![]()
NiceYes sir! That is the diff mod we have been doing. Prevents the little small screws from breaking and backing out, then destroying your gears. Also a suggestion on the driveshaft. I used thick heat shrink that has glue on the inside, used for making thick industrial battery cables. Super clean look, and have never had a drive line threaded pin back out. Easy to remove and replace for service too!
Do you know what size screw and length you used along with the lock nut for th e differentials. Cause I replaced 4 so far. I appreciate it.looks much better than before. much more beautiful
2 more suggestions for stronger diffs and axles
Its m4 but i suggest to reopen it m5 and ofcourse 12.9 grade for sure screwsDo you know what size screw and length you used along with the lock nut for th e differentials. Cause I replaced 4 so far. I appreciate it.
M4 is the stock and 12.9 is the strengh of the screw. If you don't use 12.9 grade it will brake for sure. Lenght is 12mm but again i suggest to use longer ones 16mm so in case are broken you can eject them easily. Hope help youSo 4M or 5M is the screw size? And 12.9 is the length?
Thanks alot, I really appreciate it. I going to get them nowM4 is the stock and 12.9 is the strengh of the screw. If you don't use 12.9 grade it will brake for sure. Lenght is 12mm but again i suggest to use longer ones 16mm so in case are broken you can eject them easily. Hope help you
For sure 12.9 gradeThanks alot, I really appreciate it. I going to get them now
One more question, how you get the factory screw out when it snaps off in the holeThanks alot, I really appreciate it. I going to get them now
Its very difficult thats why i suggest to get 16mm lenght so as you can eject easily in case it brokes from the longer side with a plierOne more question, how you get the factory screw out when it snaps off in the hole
