Dude just a thought,if your running discs on the front your running 3servos yeah?if you are u won't be able to put a kill switch to the engine cos your using all 3 channels?unless there's a way round it.....
Use a Y-Lead for running three servos.
j.
j.
For starters,get shut of the 40 meg and get a 2.4Ghz.You may have a faulty battery or reciever.Brakes take seconds to adjust (have you used the small bit of pipe on the end?) Your rear wheel is spinning because your diff action is working properly,but an adjustable with 90% adjustment.......solved!
J.
