John Parks
Print my own
- Thread starter
- #101
I never went through that phase with mine, I built it but never had a smoke tune or anything. I went with Idaho rob on my LBZ and his tunes were dam good and clean
I'm into 12 valve 5.9l cummins, so smoke is just part of the power aspect, it can be managed. I have a fuel control box mounted in the cab(AFC Live). Lets me "tune" when and how much fuel it get under boost. Its the closest thing you can get to a chip or tuner for the older engines. My biggest taming of the smoke was getting rid if my marine injectors. They made great power, but were very, very, very smokey. Now I'm running a set of PDD 5x20s sac injectors, and have been pleased with how they perform. Supposed to be good for 700+ hp. currently backing the fuel with a s364 stainless diesel turbo w the 5 blade billet wheel. I have a twin kit sitting here waiting for it. But the truck is getting a new frame under it first. May be one day I'll get it on a dyno and see if all the money I've dumped into it has paid off.I never went through that phase with mine, I built it but never had a smoke tune or anything. I went with Idaho rob on my LBZ and his tunes were dam good and clean
289k and counting on mine. Been very reliable, aside from self induced issues ? head gasket may have let loose one...
Studded top and bottom, head is o ringed. Extra piston clearance, dynamic balanced bottom end good for 5k rpm. Fluid damper, crank gear welded on. "Big stick" cam. Only fox stuff once my friend. Next time it goes it should be spectacular ??.Time for headstuds!
That's a fine looking rig now John ??
Just curious but what gear ratio will you be running with the 40?
Got to admit you do build some sweet vehicles. Sweet Rig . What's the big chunk of Carbon fiber behind the rear shock tower?For the SF40 build running! Dam I am in love with this rig. Had to completely redo the header but it came out perfect with the help of a buddy. May be the first titanium pipe on a scott finlay engine.
View attachment 56912View attachment 56913View attachment 56914View attachment 56915View attachment 56916View attachment 56917
