+1Now all we need are some run clips
Hopefully soon. The weathers trying to be warmer.The red stickers pop properly ?? looks awesome coop
hey coop just went through your build thread again.......... you faced some real challenges with this build
all the tr gear you put in is so sweet you wont regret it
come now i wanna see a run or feed back at least
coop you need to set the end points and travel on your servo. do it with the shell off watch the hammer and adjust with the TX until you throttle is closed no futher also set it so its a ball hair from full open. after that adjust your linkage for the bakesnoticed when putting on the brakes it does close the throttle more
nah that wont make much difference yu talking about the x port?I took the heatsink out from between the head and the header
check to make sure you don't have an air leak on the carb manifold ......its tightened down properhigh idle issue
Sounds really good ??The Idle issue is solved. I blew it up.
Just kidding. So first issue was the screw that attaches the linkage to the servo was to long. Shortened it up its good. Went to do the third heat cycle still idling out of control. Turns out the linkage was being stopped by the Bartolone Velocity stack one of the screw mounts sticks out just far enough for it to catch. A little dremeling and all good . This engine has some serious compression.
? Make sum vids pretty plz ?As the Aussies say. She's gonna be a real rippa.
Nice ? can't wait to see what u do to this one!Well now look what showed up on my Door step today. This one will be a while before I paint it . Need to look around for Ideas. I didn't realise how big the 5T bodies are.
