- Long Island, ny
- Thread starter
- #21
Does it say good for environment? If it does then I’m not using it. fiddlestick the earthThat's real environmentally safe for you.
Serious note, try it or the Citrol stuff
Alright I’ll check it outThat cow stuff was basically simple green if I remember correctly, rep was using it for a bit. I like the citroil we used it quite a bit at the machine shop for light clean up. Spray on wipe off, parts clean. It was kinda pricy from what I remember though. I just spray down with this muk off stuff. Seems to work decent, before I used a dry silicon spray. That worked too.
Yea I wanna try something else besides wd40 and simple green. The rig feels too greasy after. And I think the simple green is pulling too many oils out of the rubbers and plastics. Was thinking of using this stuff.
https://cowrc.com/MOO-Kleen-Part-&-Chassis-Wash-p69941566
https://cowrc.com/MOO-Slick-NO-077-p14380718
That’s what separates the men from the boysI sure as hell wouldn't be doing that after every run.
Figured it might be floppy but didn’t think that far after. I will probably use a Velcro strap if it becomes an issueLooks good. Are you going to use something to hold the new hose extension straight? I'm using the same thing but it flops all around. I was thinking of using a strap of some sort and attach it to one of the upper cover screws.
@BBoyz @John Parks thats the switch you guys need instead of the killer rc switchNew switch installedView attachment 76341
tube extension to clear the Bartolone pipe new pull start and header installedView attachment 76342
