- Nj
My point exactly your very quick to dismiss and I promise you won't figure it out... if you calm down with your snark pointless comments I'll tell you
Ok ok… go onif you calm down with your snark pointless comments I'll tell you
Either way refer to post #163. It will solve all your problemsYour engine has an external air leak. Those engines were known to leak past the throat of the carb you need to remove the carb off that engine and use a light coat of rtv and stuff it back in the hole and let it cure..if that doesn't work the air leak is behind the pullstart
I will if i can’t fix it , and I’m seriousEither way refer to post #163. It will solve all your problems
Here I'll que you in. Walk over that Persian rug to the kitchen. Grab the ninja good processor. Stick that 3.3 in. Set it to chop and walk away. You mommy will throw the pos out for you.
Nah the thought just passed my head and I was like nahThe fek you did junior. That's what I'm talking about snarky poop. Good luck son
Nah don’t use any of thoseCheck your fuel lines too. Make sure there are no inline fuel filters or coolers that may have worn parts or loose connections.
