Boy did I pick the WRONG time to seek nitro
My point exactly your very quick to dismiss and I promise you won't figure it out... if you calm down with your snark pointless comments I'll tell you
Your engine has an external air leak. Those engines were known to leak past the throat of the carb you need to remove the carb off that engine and use a light coat of rtv and stuff it back in the hole and let it cure..if that doesn't work the air leak is behind the pullstart
Either way refer to post #163. It will solve all your problems
The fek you did junior. That's what I'm talking about snarky poop. Good luck son
Nah the thought just passed my head and I was like nah
Didn’t even stop to consider it so ur right
Check your fuel lines too. Make sure there are no inline fuel filters or coolers that may have worn parts or loose connections.
Nah don’t use any of those
