twissted
I used the body parts in the title because it looks like a losi when I get done with it...kinda sort of, well maybe, I hope.
What you see here is a retired revo That I picked up a few years ago on ebay and seen that it needed bearings and some other broken parts. replaced. So I picked it up cheap and then I cut the frame ito 3 pieces and made a new chassis to make a longer better revo. I build somd Hot Racing CNC diffs ithe the E-Revo diff gears and then built custom drive shafts to get this crazy idea od using a HPI Vorza center diff as a trns using a gear above the deck and a smaller as the pinion gear. It's a crazy idea that should work I hope??? Any how to keep weight down I'm going with the Losi DBXL cage and body to keep it looking good and hopefully tough.
