I have hpi??
So what gears can we get now if hpi ones are out of stock?You wont see them again? everyone's out of stock?
I've got km, but still need to strip the baja to find out what went bye bye when i run it the other dayLocker or km gears (if they fit right). I'm running genuine HPI though ?
So..I started taking a look at the baja to find out what went bye, withing 30seconds I found it ?
The same thing happened last run ??![]()
Black bone is a gigantic waste of money for small bore. Go vertigo .or go the blackbone/ufc bell get one of the alloy spur carriers with blackbone bone spur 19/55
or 18/56
Helical gears, not straight cut, same gears in a normal car gearbox ??I never seen those types of gears!...![]()
Im looking at getting the rcmax 40gt eventually ?Black bone is a gigantic waste of money for small bore. Go vertigo .
The gears you will need to use with this motor will be far to small for a 40.Helical gears, not straight cut, same gears in a normal car gearbox ??
I've run them for quite some time now, same amount of teeth as standard gearing just alot more quiet than straight cut. It was a buy I thought would be good a long time ago lolYea ,that is the only place seen them at ,but not in RC!...
However ,I have seen them twist like that under nitro powered rigs if the engine wasnt lined up right!...![]()
For one they don't strip lol but performance wise there's nothing different other than they are more quiet than straight cut gears, so you can't really hear that whine when you driveI did not know that they existed for RC ,how were they on performance?![]()
I have a load of plastic straight cut with the original pinion, might put them back on? ?The problem with helical cut gears is they Induce thrust into the gear shaft. I would imagine that may be one if the issues you are having, breaking the bell shaft. Straight cut gears don't induce thrust, are typically stronger and yes noisier. You should hear 4th and 5th in my nv4500 behind my cummins..... I wouldnt go straight cut on a daily driver, but they haven't poop the bed yet.
