Cant get my losi 5ive t to start
so heres update i ordered a new fuel tank kit installed it ran great then dies ? then my pull start assembly had a hay day i tell ya i cant win for nothing
depends how u use it? and if ur car starts easily but yeah they can jus go at anytime ☹....ddm for parts ?...I jus get mine off ebay cheap?
Any recommendation on brand of pull start i seen ones with metal pawon or plastic steel cable or rope
How do i know which pull start to get there is different engine names on mine is chung yang
Could be a crack/broken fuel line or a leak on the manifold? that's what I'd be looking at first??
Its brand new fuel lines
When i push bubble couple times the yellow line has bubbles in it
What mean mainfold where do i look and how would be leaking
Once again dumb me pinched fuel line blk one
There are X2 gasket on the manifold ?? one on either side ?? but what does happen is the plastic can warp??? or the bolts come loose and you get a leak? you start your car when its running spray penetrating oil and if the idle changes as you spray then you know if there is a leak? bubbles are normal on the return ??
Ok im going check that too
Went to ddm and got some parts yesterday going be putting them on today gaskets and pull start assy have a question does any know if any where cheap to buy a losi 5ive body from here or word of mouth
