- Thread starter
- #241
sean should be able to answer it ?Wasn't sure. I was going to ask that.
Good to know but never installed the spiral diaphragm on the 990. Put it on my 1107 but not the 990. The final 990 setting on mine was 1-1/8 LSN and 1-3/8 HSN.Something I remember when watching the install videos for the spiral diaphragms on the 990 CARBS. The guy mentioned that the carbs tend to run leaner than the regular diaphragm . I wonder if that was part of the issue? Think I'll have to keep an eye out for that .
High starts out at 1 5/8th's . I've adjusted my Low needle but not the High. What's funny is mine seems to run great without touching the high needle.
?Think 1/4 would kill a piston?High starts out at 1 5/8th's . I've adjusted my Low needle but not the High. What's funny is mine seems to run great without touching the high needle.
You and me both bruh. All good tho. Still don't know 100% what killed her. Filter was new right before that carnage. I think either the piston was damaged by the lean conditions the old fuel filter gave it or the piston was damaged from something else. Either way got some new stuff on the way to get her going again.?? I just watched the gopro footage of this run and I could hear some bogging from idle to full throttle.Wow crucial I'm still gobsmacked over all this ?? change that fuel filter??
last gallon I think I added oil to the gas can???
Yup. But plug doesn't look bad to me so not sure what happened. I'm uploading the video now so I'll post it when finished.You gonna be so paranoid now? I always mix 1lter if fuel @ a time so I can get the mix right?? never forget to add oil
Thanks Sean?? What did you mean by "l side if the lip?" Did you mean inside of the lip of the seal? And am I good with a WD40/2stroke bath?The seals are so cheap id replace them. Put a little grease on the I side if the lip before you slide the case halves together.
Thanks Sean??Ha yeah phone must of auto corrected me again. Inside the lip.
make it public, its private atmThanks Sean?? Here's the video...
My bad Z, I thought yall could see it if I shared the private link. Wasn't going to publish yet. I'll post it in a few.make it public, its private atm
If you post a link as unlisted and you share the link then it works? When share the link??make it public, its private atm
