Man that's wild.
Good luck.
Better than 1 off tho! ThxMan that's wild.Good luck.
Always thought Australia was further away? Was wrong apparently. Looking into itAustralia is not that far plus their dollar has 30% less value than the US dollar id look there before the EUthat is if you don't find one on home soil
YupBetter than 1 off tho! Thx
Figured as much.It is .Europe is closer to us . Australia is half way around the planet for us. It doesn't matter whether you go east or west Australia is still half way around the planet .
Thanx ?Pulling for ya buddy! You'll get it all figured out.
I think it will work if it's only 1mm taking off each sideI've got a question, if it does come down to It, which I hope it doesn't, I might have to mod the inside of the crank webs and take off about 1mm, would this weaken it? Cuz it wouldn't thk so cuz there's so much meterial on it already.
So what the problem is is that the new rods center partView attachment 48468
Is Gunna be thicker so I wanna remove a little from the crank to allow it to pass through, would this weaken it enough to fail or?
Yup, so it should be a fine?Then balance and true everything.
Yup I'll do that as well ? Happy New yearI agree with Teejay and think it will be fine, but once again I would talk with my machinist because he would know more about the metals and their strengths.
You to Z!Yup I'll do that as well ? Happy New year
Awsome ? still I'd like to try to find a rod thin enough to fit the crank without modding, like I've said, modding is the last resort, but it's good to know that it'll b fine. Still will talk to the machine shop just cuz ?? happy new year, make this new year great!!!!!!!!! ?Your not gonna hurt it. The small amount of material your taking out shouldn't be an issue. Like said above getting it balanced and trued will get you back to point A again.
