Doug's hpi 5B SS
Ah right radio box ??
not a bad idea. i gotta look into it. ??
i gotta see how hard is it to design.
how many companies making baja boxes
how much room i got to work with
if my friend can lend me his baja i will have more ideas
Can I make a suggestion ? sure you'd do this anyway?? only use genuine hpi parts to get your dimensions ? coz the clone parts can be hit and miss?‍♂️?‍♂️
Might want to look at both though. Rovan is only gonna become more and more common
K so I bought the ufc clutch right ?? so far all good ?. Came with a turtle bell?? so you'd think fitting would not be a problem ? well you'd be wrong? the bell and the shoes damaged the v2 clutch bell and housing ???‍♂️ sharp edges on the bell??????20200822_143732.webp
So to fix it I put shims and got out the dremel?‍♂️ and I put a hole in the bell housing???20200822_143755.webp
Then just to add salt to the wound my crank seal sprung a leak? oil round the transmission and was a bit in the clutch ?20200818_141117.webp
No problem I'll get a new seal (specs 32 x 12 x 5.5) can only find 32 x 12 x 7........dose not work coz the clutch plate touches ?‍♂️ have to make a special order......ill get next week some time20200822_143902.webp
So now for the little bit of good news?
I have a different clutch plate its a tad taller so shies won't touch??20200822_145004.webp
And someone local had one of these for sale so I should have that next week as wellScreenshot_20200822-145150_Samsung Internet.webp
So all this got me think .....OK FFS!!!!!?
This chassis is set up to take more power?? and with the new bits baja now I may sell the new rig ......maybe the reed obr and see what I can get to slap in the SX5???
K so I bought the ufc clutch right ?? so far all good ?. Came with a turtle bell?? so you'd think fitting would not be a problem ? well you'd be wrong? the bell and the shoes damaged the v2 clutch bell and housing ???‍♂️ sharp edges on the bell??????View attachment 62514
So to fix it I put shims and got out the dremel?‍♂️ and I put a hole in the bell housing???View attachment 62516
Shoes catching on the clutch housing ?‍♂️?‍♂️?‍♂️??????View attachment 62515
Then just to add salt to the wound my crank seal sprung a leak? oil round the transmission and was a bit in the clutch ?View attachment 62517
No problem I'll get a new seal (specs 32 x 12 x 5.5) can only find 32 x 12 x 7........dose not work coz the clutch plate touches ?‍♂️ have to make a special order......ill get next week some timeView attachment 62518
I have a different clutch plate its a tad taller so shies won't touch??View attachment 62519
And someone local had one of these for sale so I should have that next week as wellView attachment 62520
Damn that sux ?? well at least you got a solution ?
