I'll say it once junkie. When you eliminate the terrible delrin gaskets ddm gives you because the carb and intake gets loose your effectively taking away the point of those gaskets. The aluminum is now conducting the heat from the head and its traveling to the carb. Like I said ive had this happen and the carb was extremely hot and it vapor locked to the point I couldn't even prime the bulb and what little fuel was in there was boiling
