Mick Boomer
- Reaction score
- 990
So what is your favorite exhaust gasket? Loctite on header bolts?
That’s what I runfave exhaust gaskets are these mick, i use em on everything if i can,
https://www.davesmotors.com/Super-Heavy-Duty-Steel-Reinforced-Graphite-Exhaust-Gasket-fd227?sc=12
and yes i use a red loctite thats supposed to be heat resistant on exhaust bolts,
tbh it still softens with the heat of the head though![]()
If I put a sring washer on with the Jetpro rear mount I can't get the already shortened hex key in.Spring washers and a copper gasket no loctite best results![]()
The gasket has some material (idk what it’s called) than it has metal and then another layer of material. It’s a horrible design and the material sticks to the exhaust port and pipe and is a pita to get of its sticky af. This design is mostly used by Rovan (no surprise thereFirst off @RcJunkie13 wtf kinda sandwich you making kid?
Get 5×25 and your golden
