Don't do it mate..The holes are on the cooling fins so i can't drill and screw them there xD
Today i order new fuel primer for my carb because it broke lol. Was old and lost it's elasticity.
Guys do you think that a fuel pump will make any difference
Also i had one more idea. To order a cylinder and piston for zenoah 26cc marine and install it on my engine
I'm the kind of person who can't stick with stock products for too long????![]()
Don't do it mate..
It will heat seize without cooling fins, unless you can find a darksoul billet cylinder shell but good luck with that ???
Guys it's obvious that i will install radiator and pump.
I ain't noob in mechanics ?
I'm electrical engineer and mechanical engineer don't worry
i cleaned the carb, it's like brand new, all it needs is the fuel primer.?
I will try to setup the walbro from my 46cc chainsaw but the problem is that it needs crankcase back pressure. :/
Here was a quick test after cleanup, you can see how it's leaking gas from the primer?
and yes i had much more oil in gas on purpose xD
Ah no worries mate. For me there is always something to learn no matter the backgroundWell I didn't know your background,so I start at the beginning.
A lot people just starting out show up and try to help best I can.
Telling us your background would've saved time,in me trying to simplify everything.?
Oh cool since you know about watercooled pc, my idea was based on pc water cooling ? a radiator with single fan or push pull set up so it will fit on the model and a 12v water pump.Funny I thought about that before also, Ive seen one in real life. (This was a thing years ago)
His ran ok for short periods.
He had thermal issues, cooling capacity/packaging among other issues and would've needed larger/more efficient/effective cooling parts, rads/fans/higher flow pump.
There's also diminishing returns past a certain point,so it's a balancing act. You'll need preferably the smallest components that'll complement each other for the most effective + efficient cooling system.
Fitting all this on a small rc chasis won't be easy.
I'd start with a larger vehicle.
Cooling in no particular order:
Engine thermal output(heat pump), cooling efficiency- radiator/s+fan size+efficiency, water flow,Airflow even tubing size+ length,ambient temps,engine load/speed,heatsoak.
Living in a colder climate would be a.
If you can overcome the cooling and it be robust enough for hits, tumbles it would help.
At the time the available w/c stuff used was for pc's.
There might be a better solution to handle the heat these days. It was several years ago when I saw his car.
There's a reason why it's not a thing,it's just too complicated and really not efficient for this type of vehicle. It was looked at and experimented with by rc makers as I said earlier.
I remember a guy trying to use a self contained prebuilt system,it was a spectacular fail.?
Some of my wc community people might be interested in the challenge.
Your an engineer,you should have some ideas-?. I know - just joking with you.
I deleted a reply that became a unfinished novel explaing some of the dynamics.
I decided on a simpler post.?
(I'm experience at building watercooled computer systems+)
Is there a particular reason you want to use watercooling besides "The cool factor?"
Dang now you have me thinking about it again.
Edit---- ---
Well you came to right place because there's a lot of seriously knowledgeable chainsaw people here.
Hopefully one of them can help you with the carb issue.
