Bandit2013
- North Carolina
- Thread starter
- #41
I have the same issue with the Kraken Vekta KV5TT fuel tank. I bought two quick fill caps that have the metal filter breather. I can take out the rubber nipple gasket from the stock cap and use that to seal the cap to the tank. I did think about removing the small rubber flap on the plastic insert. That set up only lets pressure out due to vapor expansion assuming it is more positive pressure compared to outside of the tank. As it seems, the tank has negative pressure that pulls the rubber flap on the plastic insert inward and seals the tank. Vent hole will do nothing. I can experiment by pulling the small rubber flap off of the plastic insert. The cap will breathe better. Either that, just remove the plastic insert, no need to modifiy it. Will see if that works. I could always change the tank gromet and add a breather line and filter. Just trying to keep the mods to a minimum for now. Spent enough money.Make sure the vent hole in the gas cap is open and not clogged ( you can even drill it out a bit bigger)
Also make sure the rubber valve in the cap is working properly
Some trucks had an issue with the cap not letting air into the tank as the fuel was being used up thus causing the engine to die out
