alcohol helps reduce combustion temps, nitro plays very well there.
with gas, I'm using less then 5%
anything more and i'm really fighting temps.
Something i learned from watching burnout comps, some guys run off of alcohol as it really reduces engine temps.
When your running WOT, high RPM, lots of load, and not really moving overheating is a thing.
alcohol = lower engine temps.
They even found you can run a smaller radiator!
It really opened my eyes to why alcohol is used with Nitromethane.
And i'm sorta hoping i fry this thing, one hand i can rebuild the engine and do some porting/cleanup while it's torn down.
Other hand, i can just spring for a better engine.
and the rc is all fixed up.
I also cracked my steering servo saver arm...
so i just bought an entire assembly, metal one this time around...
then while installing that, i managed to break off a steering ball joint, managed to extract that from the new steering set...
and then a few more days waiting on some new tire rods with ball joints.
drilled and tapped the chassis for the front brace, so it actually threads into the chassis, then top it off with a nut on the other side.
Now to see what i break next.
